Yep tons of them here I'm in the middle of one right now. Just search supermax Viper200
Well Group, I've been mulling this over for a while.. converting my SuperMax YMC-30 CNC Milling Machine. It has a working Anilam "Crusader II" controller on it.. but for what I want to do - the controller is memory limited (albeit incredibly functional for a product of the mid 1980's ... hats off to Anilam).
The Anilam is older (386 based)... and just not able to do what I want to do with the machine (Mainly drop gobs and gobs and gobs of G-code to it.... )
Therefore I am trying to decide which way to go with the retofit.. Larken, Gecko, etc.
I have had very good luck with Gecko stepper controllers on lesser powered applications... and I could downgrade the voltage and run Gecko 320's..
After thinking about it .. I decided not to drop the power to the cnc in favor of the Gecko's ..as I'm like Tim the Toolman - and I always side on things having "More Power".....
Therefore I started looking at all the aftermarket stuff available to the home DIY'er on a somewhat of a ShoeString budget....
I am leaning toward the Larken's after calling Larken up and actually talking one on one with Larry Kenny - founder of LarKen .. Larry is incredibly knowledgeable, and has built his controllers for the high powered user. I like that. I want to keep the power going to my servo's.. and keep that table fully moving..
I'm going to do a very detailed build log and probably put it in a PDF format and put it out on the CNC-Zone, so others can benefit from it.
Has anyone done a Larken conversion of an Anilam system?
If so - please contact me here.
Anxious to get that beast upgraded,
Joe
[url]www.CNC-Joe.com[/url]
CNC Is Not Just My Passion.. It's My Addiction !!!!
YCM-40 converted from anilam to Mach3 and lovin it.
Thanks CWAugs!
Joe, this servo drive review might help you out.
http://www.thecubestudio.com/ServoDriveReview.htm
UCCNC 2017 Screenset
CNC-Joe, Check out the Viper Servo forum for more threads on mill conversions.Has anyone done a Larken conversion of an Anilam system?
http://www.cnczone.com/forums/forumdisplay.php?f=349
Yes check that out. It was a lovely experianceJoe, this servo drive review might help you out.
